Extra info:
As you can see a 2 door hardtop, vinyl roof, 383 with a Edelbrock 4-barrel carb. Carter carb in box in trunk. Console shifter, PS, PB. Brakes gone through last summer with new master cylinder and wheel cylinders on fronts. I replaced gas tank, fuel lines to fuel pump, fuel pump, cleaned out Edelbrock carb. New points and condensor. Runs, drives. AC doesn't work nor does vent, heat or fan. Can hear some motor sound when turned on but nothing comes out vents. Has what appears to be a factory radio but doesn't work. There is a aftermarket radio under dash which does work. Good car for someone to play with or restore. Dash pad cracked in several places. Foam in seats dried out, foam crumbs here and there.
Glenn
