New build stroker 383 dyno numbers
Radical Fred
Moose Jaw Saskatchewan
Hi, just had my stroker 383 dynoed and it made 521 hp and 612 ft/lbs of torque. should pep up the 66 fury 3.
Congrats!
Intake, carb, cam, and cyl head specs? What final stroke length and CID? Just curious.
Take care,
What compression and camshaft if you don't mind sharing?
What rpm for peak torque and HP or a Dyno graph better yet?
Very nice numbers! Football field torque!!
A little lean there in the middle but great numbers. Won't really need much stall if any and will pull 3.23 gears all day long.
No need to Rev it to the moon either. Hardly ever see 5000 rpm unless you are chasing a time slip.
Would love to know what cam when you have the time.
Excellent results!
Excellent results!
factory 4 speed car with 3:91 suregrip. I will send you the cam specs when I get home.
I hope you have a good rear suspension,u joints,and driveshaft!:lol:
If it hooks you better hold on!! I will recommend a bias type rear tire for any dragstrip action.You will want some sidewall flex to absorb some of the driveline shock.
The 505 in my Duster makes North of 600hp and TQ so I went with 3.55 gears. With all that torque I didn't need low gears. Enough about me, have fun and enjoy it!
