Wonderwagon
What size tire and is the rim a stock size, good look.
Wide steelies with dog dishes work on every car They work quite well on some cars but certainly not this one.Don't listen them, those look really good!Wide steelies with dog dishes work on every car
I think a nice set of road wheels would be the best for a wagon of this quality
Where are the white walls - why am I the first one to mention this??? Keep the original wheel covers.
But I don't doubt for a moment that wagon drives much better with the wide wheels - the wagons were well noted for "tail wag", bad enough to be disconcerting at times.
My preference is also for the original wheels and WW, but to each his own. I agree with @Tobias74 that wheels are a simple change. Since he's preserving the originals, no harm done.
This being said, I am very interested in your comments on the "tail wag." Is this specific to wagons, or to 69's? I understand that the rear track was widened for 1970, and the stance of the '70s is why I focused on this when looking for a 'vert. I was no aware of handling issues, though -- care to elaborate?
It was endemic to all C body fuselage wagons back in the day in my experience - I haven't owned other Mopar wagons so I do not know about the slab sides, for example or the formals either, but unless there were some changes to the formals compared to the fuselage ones, they probably exhibit the same tendencies I would expect.
Wagons had very heavy dual action tail gates and my wagons have all had dual a/c, which didn't help. Mine also had radials with not as stiff side walls as bias plies, so that didn't help either. Also the weight of the tailgate is positioned quite a ways back from the rear axle probably to preserve the wheel base close to that of the sedans. The front tire pressures are specified to be 22 psi while the rears were supposed to be 32 psi. Given the large amount of weight positioned beyond the rear axle and the low front tire pressure specified, directional stability suffers such that even just correcting the steering wheel slightly when driving down the highway will induce some tail wag, i.e. the rear doesn't want to follow the front. Having a sway bar back there would have helped, but it would have also made spin outs more likely. The engineers were treading a fine line on acceptability with those wagons IMO. I would have installed a heavier front sway bar and a rear one as well (keeping a proper proportion though at the rear to minize this and still avoid spin outs when maneuvering sharply at speed). It feels kind of like towing a trailer with not enough tongue weight and the center of the load too far back in the trailer. Even wider wheels than the 6 1/2s that came with the wagons would have helped. But note also, that each of these things would have added significant cost which they did everything to avoid of course.
And I agree with you that it is Tobias' wagon to do with it as he pleases, and his modifications are easily changed. We all have our preferences and just like to tease is the way I see it. No one can be on this site much and not have a thick shin. I am called "pompous" in another thread, while the same commenter just gushes over the most pompous man in the world that I have ever seen, and he occupies an office that is oval in shape. So you just have to flow with it!
I'm concentrating on this paragraph, Steve.Wagons had very heavy dual action tail gates and my wagons have all had dual a/c, which didn't help. Mine also had radials with not as stiff side walls as bias plies, so that didn't help either. Also the weight of the tailgate is positioned quite a ways back from the rear axle probably to preserve the wheel base close to that of the sedans. The front tire pressures are specified to be 22 psi while the rears were supposed to be 32 psi. Given the large amount of weight positioned beyond the rear axle and the low front tire pressure specified, directional stability suffers such that even just correcting the steering wheel slightly when driving down the highway will induce some tail wag, i.e. the rear doesn't want to follow the front. Having a sway bar back there would have helped, but it would have also made spin outs more likely. The engineers were treading a fine line on acceptability with those wagons IMO. I would have installed a heavier front sway bar and a rear one as well (keeping a proper proportion though at the rear to minize this and still avoid spin outs when maneuvering sharply at speed). It feels kind of like towing a trailer with not enough tongue weight and the center of the load too far back in the trailer. Even wider wheels than the 6 1/2s that came with the wagons would have helped. But note also, that each of these things would have added significant cost which they did everything to avoid of course.
Possibly the best wheel cover of all time. They'd fit on the cop wheels too, I think...
