Newer reared in a 62 880
Pops62
Spring branch tx
can anyone tell me if there is a direct bolt in rear ended I can put into my 1962 880
I would also like to run larger rear brakes.
Thanks
Thanks
Your best bet will be to go to a '65-67 B body 8.75" rear end. Your drum to drum width for '62 rear end is 58 1/2".
The 65-67 rear end drum to drum width is 59 1/2".
The 65-67 rear end has spring mount pads that are about 1" further apart so you either need to have each of them moved 1/2" inboard or you can do the old hot rodder's trick of drilling new pin holes in the mount pads and weld the old holes shut. Did that modification many times in my misspent youth.
In answer to your original question, there is no direct bolt in without the above mods.
Thanks
A chart with the rear axle width drum to drum is attached in the PDF below, click Mail 0086 to open.
  • Mail0086.PDF
Thanks I will start looking for a housing
I have a challenger rear with sure grip so I will keep that and brakes
