I did a check on this Formula S car and a grade 4 is around $7600 so this fellow, at $5500 is not far off since grade 5 cars are negotiable below grade 4 drivable.That's actually kind of a rare car from what I understand. Most of the 273 engines in the Barracudas were the 2bbl low compression engines. The optional 273 Commando was usually ordered as part of the Formula S package.
I think the price is a bit optimistic for the work involved.
I posted, thinking about yours, you need 2That's actually kind of a rare car from what I understand. Most of the 273 engines in the Barracudas were the 2bbl low compression engines. The optional 273 Commando was usually ordered as part of the Formula S package.
I have other cars I "need" much more... LOL.I posted, thinking about yours, you need 2
I just checked Hagerty's values on a non-Formula S with the 273 Commando and I'm kind of surprised. To be honest, I haven't been following values on these cars for quite a while. This may be in the ballpark after all.I did a check on this Formula S car and a grade 4 is around $7600 so this fellow, at $5500 is not far off since grade 5 cars are negotiable below grade 4 drivable.
I never pay attention to Hagerty's estimates as I feel many are way out of line. That even though my insurance is with Hagerty. Sometimes I wonder if they are basing their values on what people insure their cars for. Not as though owners don't over state the value of their cars, rightI just checked Hagerty's values on a non-Formula S with the 273 Commando and I'm kind of surprised. To be honest, I haven't been following values on these cars for quite a while. This may be in the ballpark after all.
Being a 4spd added 10% and the car is pretty much all there and doesn't look like its been screwed with too much, so that is an advantage... But there's a ton of work there and there isn't much (if any) good repop sheet metal available except for some random patch panels.
It is much easier to deal with a car that size on many levels.OTOH, it would be nice to have a car this size in the garage for a change.
That actually used to be my car. Sold it in 2013. Owned it since the 70's. I had 15x8 Keystone wheels on the back that were some special ordered offset for a Corvette that were never picked up at the local speed shop, so I got them for cost. Had an L60-15 (shows how long ago that was) and then went to a 275/60-15 when radials became popular.What tire and wheel combo is under the 69 road runner? They fill up the wheel well nicely!
And!! They are a ball to drive. The 273 Commando is a pretty good motor for these cars. Most likely that has a 3.23 Sure-Grip and that makes the rear a lot stronger as it's the spider gears in the open 7 1/4 rear that go bad. The Commandos used a 10 1/2" clutch.
The downside is the engine compartment was designed for a slant six, so it's a little narrow. Tough to change a starter, but one of those new starters works out a ton better.
I have a friend that built a '66 Valiant with a hot 340/4 speed years ago. That car was actually kind of rare in that it was a 273 Commando 4speed, but as a 340, it was (still is) a rocket. He beat on that car pretty good with the 273, then with the 340. The 7 1/4 with the Sure-Grip actually held up to his pounding on it, but he went to an 8 3/4 because he knew it would break eventually. But... It didn't break and believe me... He never showed that car any mercy.Interesting on the SG 7.25 lasting a bit longer than an open one. I'm not a big abuser, but I figured 300hp thru it would eventually break it.
I stand corrected. I looked in the FSM and see that now.Sorry, no. They have a 9 1/2" clutch. The aftermatket and the factory 10" A100 clutch has a scalloped pressure plate and special attaching bolts, that works on the
9 1/2" flywheel.
Its byooteefulThat actually used to be my car. Sold it in 2013. Owned it since the 70's. I had 15x8 Keystone wheels on the back that were some special ordered offset for a Corvette that were never picked up at the local speed shop, so I got them for cost. Had an L60-15 (shows how long ago that was) and then went to a 275/60-15 when radials became popular.
The present owner is a good friend and I can't remember if he has new wheels on it or not. But the combo is basically the same.
It is an A12 car, but he couldn't lift the hood, so he has a repop hood with hinges.
Picture taken at the same place (Syracuse Nationals) but different years.
