SOLD Not Mine 1968 Chrysler New Yorker Coupe - $2,000 - Regina, Saskatchewan, Canada
T-revorNobody
Sidewinder, Colorado
FB Description
1968 Chrysler new yorker 2dr hardtop. 375 hp 440 4 bbl with factory Holley carb. auto and dual exhaust black inside. now black outside (was green). power steering. power breaks. power windows. power seat. power trunk and tilt wheel and wheel skirts. was driven daily 3 years ago. was turning over fine but the starter is bad and the carb leaks now. easy fixes!. some rust around the back wheels but this car is very rust-free otherwise all the chrome that looks missing is in the trunk $2000 call or text only...[hidden information]
Not an HP 440... I'll wager it's not even the original K code 350hp 440.
Mid 70s exhaust manifolds, valve covers, distributor and air cleaner. Cant see if that is just a cast bridge by the distributor, or the cast boss there, so it may even be a 400. If I could see lower you probably would note a cast crank as well and under the air cleaner will likely be a Thermoquad.
Hey; but all the smashed and bent trim is in the trunk, except the rear pieces they left on and painted over to cover the rust.
