NOT MINE Not mine 69 Polara 2dr - $500 - Idaho
71Polara383
Kid with ballcap
Rockford,IL
Saw this on Facebook. Guy claims he's gonna junk it. Looks like it could be salvageable? If not a great donor car. I wish it was close by.
One of you up in the North West should go get that! Big block 69??? Hell yeah! I’d go get it but I swore off C body projects.
Brilliant, lets park a nice car under a pine tree, fill the cowl and every other crevice with pine needles, cover it with abrasive pine sap, and let it rust to pieces.
Yeah I don't facebook either and am pretty close. If somebody could get me the contact info I'd see what its all about and probably bring it home.
Are you guys seeing something I’m not?!? That is a 2 barrel carburetor. Also, If it had 4 barrel exhaust manifolds you be able to see the driver side as it has a large upsweep and would be visible. I’ll admit the pass side looks like a 4 barrel exhaust manifold from that angle. I guess the vin will determine what’s up for sure.
Could be a old boneyard heat riser fix, simpler for some to R & R the manifold with a working junkyard one as the heat riser replacement kit required some tack welds.
Could also be a boneyard replacement for a cracked manifold. A unforeseen bonus that they got the HiPo manifold from the Pick & Pull.
Only the FT & build sheet will tell what came from the factory.
I kind of like it leaves and all, looks about as complete as you can get for 500 bucks. But then there is the no title, a trek across the continent in treacherous winter weather driving conditions, and being in North Idaho it is most likely buried in snow in the back lot. So bring your plow.
