peiguy23
My 383 starting missing this morning. When I pull the wires off the timer cap, number 6 isn't firing. There is no spark between the cap and the wire when you pull it out of the socket. If I hold it in the socket for number 3 it sparks, and the number 3 wire will not spark if moved to the number 6 socket. I'm not changing the firing order, just moving the wire as a test.
I have a Pertronix coil and a Pertronix conversion kit in the timer. I also noticed that my tach is jumping around and not showing a smooth and steady RPM.
Any ideas?
Thanks
Any ideas?
Thanks
