There are two more small code blocks with Dodge franchises, assigned mainly during the 1960s. That makes them parallel blocks to the upper half of the 51000-59999 block. They comprise both about 100 code points, the first one starting at 20000 and containing only four dealerships in the 1986 file (#20013, #20053, #20068 and #20069). They are all Dodge Truck-only and by 2009 these are all gone. The second block starts at 25000 and is more tricky. That's why this post will be longer than usual.
Most dealerships here have stand-alone Dodge franchises, only a few combine them during the 1960s with Chrysler, Plymouth and even Imperial:
25046 Freeman Motor Co., Inc., Lumberton, NC, Chrysler-Plymouth-Imperial-Dodge dealer since 1956;
25078 Bollinger's, Inc., Lakeview, MI, Dodge dealer since 1914, Dodge-Plymouth dealer since 1929, Chrysler-Dodge-Plymouth dealer since 1954.
That were rather unusual combinations for the 1950s. The Chrysler-Dodge-Plymouth dealerships generally arose later.
Dealerships that go back to at least the early 1950s, sometimes under different names, used to have Dodge-Plymouth franchises before they passed to Dodge-only, as can be expected:
25001 Ellsworth Bros, Inc., Idaho Falls, ID, Dodge-Plymouth dealer since 1945, Dodge dealer from the 1950s;
25010 + Morgan Motor Co., Inc., Wichita Falls, TX, previously a Dodge-Plymouth dealer, Dodge dealer since 1959 or 1960;
25040 + Spencer's Dodge, Inc., Wichita, KS, Dodge-Plymouth dealer since 1941, Dodge dealer since 1958;
25049 + McEvoy Dodge, Inc., Rochester, NY, active as Dodge-Plymouth dealer around 1946-1954, Dodge dealer since 1964;
25064 + Miller Motor Car Corp., Binghamton, NY, previously a Dodge-Plymouth dealer, active as Dodge dealer around 1969;
25071 + George T. Abood, Inc., Portsmouth, NH, active as Dodge-Plymouth dealer around 1954, Dodge dealer since 1957.
The newer ones started out with Dodge-only franchises. Notations like "1964/1967" indicate data from conflicting sources:
25002 + Dodge City of Utica, Inc., Yorkville, Dodge dealer since 1957/1958/1959;
25004 + Dependable Motors, Inc., Austin, TX, Dodge dealer since 1959/1960;
25006 Bill Breck Dodge, Inc., Tucson, AZ, Dodge dealer since 1959;
25007 + Bill Breck Dodge, Inc., of Colorado, Colorado Springs, CO, Dodge dealer since 1964;
25009 + Albany Dodge, Inc., Albany, NY, Dodge dealer since 1961;
25015 + Hampden Dodge, Inc., Springfield, MA, Dodge dealer since 1962;
25019 + Sam Dells Dodge Corp., Syracuse, NY, Dodge dealer since 1966;
25023 + John Ryan, Inc., Green Bay, WI, Dodge dealer since 1955;
25024 Frontier Dodge, Inc., Modesto, CA, Dodge dealer since 1966;
25034 + Dishman Dodge, Inc., Spokane, WA, Dodge dealer since 1962;
25036 Jensen Motor Co., Goodland, KS, active as Dodge dealer around 1973;
25047 + Deloach Dodge, Inc., Monroe, LA, Dodge dealer since 1967/1968;
25054 + Reno Dodge Sales, Reno, NV, Dodge dealer since 1965/1969;
25055 Lochmandy Motor Sales, Inc., Elkhart, IN, Dodge dealer since 1967/1968;
25056 + Tom Matson's Valley Motors, Auburn, WA, active as Dodge dealer around 1972;
25062 Charlie Zook Dodge, Inc., Sioux City, IA, Dodge dealer since 1964/1967.
For some unknown administrative reason the franchises in this block must have been different from those in the upper half of the 51000-59999 block. My best guess is that these codes are connected with "high-performance dealerships". For 16 out of 24 dealerships you find that they handled Dodge muscle cars, selling them or sponsoring them in races. In the lists I added a "+" sign for such dealerships. The muscle car phenomenon is a typical Sixties thing and so are these codes.
But handling muscle cars is also done by dealerships that have a normal 5xxxx dealership number. Take Norman "Mr. Norm" Kraus' dealership, the most famous of them all:
57147 + Grand Spaulding Dodge, Chicago, IL, Dodge dealer since 1962.
That dealership was intended to be a high-performance dealership right from the start. But, says Mr. Norm, "each high-performance customer had parents and probably a brother or sister who needed a car. ... They also had friends and co-workers who needed a car. That's what we wanted - the whole market. Our niche was to get started in high-performance, then we increased volume, and then diversified" (Robert Genat: "The American Car Dealership", pp. 84, 85).
That seems like a neat explanation for Grand Spaulding's dealership number, but many 25xxx numbered dealerships likewise served the whole market.
There's still another problem with this group. For three dealerships alternative codes have been recorded:
53059 (1959) Bill Breck Dodge, Inc., Tucson, AZ, cfr. #25006 (1986);
53141 (1960) John Ryan, Inc., Green Bay, WI, cfr. #25023 (1986);
57359 (1966) Spencer's Dodge, Inc., Wichita, KS, cfr. #25040 (1969).
I included the year in which the codes are known to have been in use. It could well be that those dealerships received new codes when the older franchise agreements were replaced by new ones. That sounds good and is supported by the years the older codes were recorded, but the company that evolved from Spencer's Dodge after its sale in 1982, Davis-Moore Dodge, Inc., turns up in the 1986 file with the older code, #57359! So that older code never went away. Maybe the 5xxxx numbered franchise agreements were not replaced, but remained valid alongside the 25xxx ones. That's not unusual if the franchises are being operated at different locations (see Bill Breck in Tuscon and Colorado Springs), but at the same location and under the same company name?
As you see, the going is getting rough; I'm just not sure. That's why I listed all relevant dealership numbers. Maybe somebody with more knowledge of 1960s Dodge dealerships could chime in and come up with a completely different explanation.
