Contacted Mikes carburetor (seems like a decent guy) and he told me that after a carb rebuild (which I did) a very common issue is grit from the fuel system flushes through the carb and sticks in the needle and seat. I didn't believe it cause the needle and seat were brand new and they held air when I blew through a tube connected to the fuel inlet. But I knew floats were ok and fuel pressure was around 4 psi so I replaced needle and seat. Presto - fuel stopped leaking from EVAP cannister and bowl vents. Now all I have to do to the carb is helicoil the front bowl bolt holes that I striped.
The second problem still exists (i.e. exhaust smoke coming from carb throat when first starting). Because this problem disappears after initial start up and the car runs smooth after initial start up I don't think its a timing problem. I'm leaning more toward it being a stuck valve that unsticks after startup. Thoughts? Paul
