greasemonkeyman
Hi,I was considering on doing an overdrive transmission swap on my 1967 Chrysler New Yorker,440 Engine,727 Automatic Transmission.I was looking to get better gas mileage because I may do a little traveling on the highways with it and put some mileage on it,like family vacations,etc.(a few hundred miles per trip).I was told that the A-518 was the transmission to use but have some questions concerning the swap:
Will the engine bolt to the transmission without an adaptor plate?
Can I use the stock torque convertor that comes with the A-518 and will it just bolt up to my flexplate or do I have to change flexplates?
Will my stock column shift linkage work or do I have to modify it for the overdrive gear?
I understand the A-518 transmission is longer than the 727 it will replace,so shortening the driveshaft is going to be needed,but do they both use the same output yoke or do I need an A-518 output yoke to be mated to my 727 driveshaft?
I will be using a good aftermarket transmission cooler,so the transmission lines will be plumbed to that because I think the lines are a larger diameter in the A-518 transmission.
Since the A-518 is a longer transmission(tailshaft area) has anyone built or modified their transmission crossmember and what is involved in doing this? How much further back is the transmission mount compared to the A-518 mount?
Also,are there any modifications to the transmission tunnel required in a 67 C-Body to get the transmission to fit?
I think I've covered just about any and all possible questions about doing this swap,but please feel free to provide any extra input I may have excluded.
I was curious if any of you out there has done this swap and how your gas mileage has been before and after the swap? Is it worth all the trouble or is there a decent increase in mileage?
