polara71
Stop it! Bob posted that long before You ate your words ..........:bighug:
Most of us know we will be negative on our restorations and do them for the fun of it or to have a car we may not be able to afford to buy done.
Alan
You have to do the math on the highway rpm has to be above 2000 at the speed you would like to cruise at.
mph | final drive ratio | Top Trans gear ratio | Revolutions per minute |
75 | 3.55 | 1 | 3626 |
75 | 3.23 | 1 | 3299 |
75 | 2.94 | 1 | 3003 |
75 | 3.55 | .69+lockup | 2252 |
75 | 3.23 | .69+lockup | 2049 |
75 | 2.94 | .69+lockup | 1865 |
65 | 3.55 | 1 | 3142 |
65 | 3.23 | 1 | 2859 |
65 | 2.94 | 1 | 2602 |
65 | 3.55 | .69+lockup | 1951 |
65 | 3.23 | .69+lockup | 1775 |
65 | 2.94 | .69+lockup | 1616 |
....2.94-3.23 with a .69 od and tall rubber your 65mph rpm is in low 2000s hard to pull anything that low but flat or downgrade, now if you want to cruise at 80-90 mph steady for an hour I can definitely see it. can't do that here in pa. because of traffic so its not really on my list.....
I didn't say don't do it just anything taller than 3.55 it just won't pull with a .69 od. I put a 440 in a 69 barracuda it had a perfectly good /6 did it because I wanted to go faster not cause it made sense or cents.
GM guys do it all the time because there's nothing they can't do by simply giving Summit a call. No matter what they want to do, somebody will sell them a plug n play part. No thinking required. Us? Bupkis!
Posted via Topify on Android
