commando1
Never go to Jiffy Lube.
I'm running pertronix on two of my cars and they work flawlessly.
I just went with the basic kit though, why Ignitor III?
That is what I was thinking. The III is basically overkill for a street car (low rpm) like ours.
I have Ignitor II and Flame Thrower coil, runs same with or without ballast. Since the resistor could fail (open) likely best to bypass.
300cruiser, I have a Igniter II and Flame Thrower Coil that I've yet to install simply because I'm not 100% sure of the RED wire connection. What did you connect the RED wire from the igniter to? The instructions (figure-3) seems to indicate somewhere before the ballast resister? From the same figure-3 it looks like one side of the ballast is connected to the (+) side of the coil AND the other side of the ballast is where RED wire is connected to. Would that be the incoming (+12VDC) line to the coil? I'm confused......
