ok so I've done several of these conversions on lean burn systems but never a points system. Today Scorch got her new Mopar Electronic Ignition Conversion halfway installed when I ran into a problem with the Run circuit side of the ballast. The kit says you need to run Key On power to the run side then split this circuit to the ECM which in turn energizes the coil. My problem is where to pull key on 12v from? Tried several circuits under the hood with no luck. Suggestions? Its the blue wire circuit below that i'm hung up on. The old points system does not seem to have this circuit. 1970 300 440 btw
