hotpursuit
Anyone have a modern replacement idea for '69 Polara pursuit shocks? What would fit and perform the same as original?
Your resto has been flawless in attention to detail so is this going to be carried to the rear shocks also or is that detail being given a pass?Probably any modern shock, that is my plan at least.
The CHP used the factory front shock and a heavy duty rear that wasn't a shock used on other cars from the factory.
Alan
What are the rear shocks spec'd to?
http://www.p-s-t.com/Products_2/Products/Shocks
PST carries Bilstein shocks for our C's, I dont know if you'd find better
I thought there was a fitting problem on the front?
Is it just a little extra effort, or do you beat it with a hammer into submission trouble?There is always a fitment problem with front shocks , at least on a Fusey anyway
are police shock absorber the same thing as "cop shocks" ?
Only if they are used in conjunction with "cop tires and cop suspension"
I have never had to drop a control arm but they do need to be persuadedHave you ever changed shocks on one of these cars? If that sucker is even a 1/8" larger in diameter it isn't going in without dropping the lower control arm.
Alan
