Hi, I have posted this last year and have been checking for the vibration but it is still present and seemingly getting worse. 1965 Fury poly 318, 120k miles ,all stock, we replaced water pump, timing gears and chain with double roller in 2022.timing chain was tight on left side, but sloppy loose on the right side as you look at it. vibration started right after that replaced with new vibration dampener seemed to get better but now has become very significant between 14 and 1800 RPMs. seems fine at idle and above 2000 rpms.have disconnected all belts, vibration is still there, checked in park and neutral, vibration still there,new driveline (vibes while parked) fluids all full, runs well.runs elect.ign, rebuilt BBD Carb. Oil pressure is 25 warm idle 48psi warm cruise. Compression is 145-155 ,others suggested torque converter or flexplate. Is loose ?? All ideas appreciated, Davea Lux ?
