Interesting thread. My 2 cents:Thank you it currently has a dual master cylinder but the brake booster doest look in the best of shape. But its working. No I don't plan on driving in any large puddles lol but I am in Florida we get heavy rain every day starting at 4pm. But once again thank you for your advice it will save me and my bank account alot of grief. So I will just make sure my drum set up is sound and I should be good to go
Discs are superior in every way, period. #1...easier to service, fewer parts.
#2...better heat dissipation...Brakes work as heat sinks, converting kinetic energy to thermal and radiating it away. Discs do that better. As to the master cyl., the one you have (drum-type) isn't the same as disc/drum MC...differences in reservoir size & capacity. Also, in Rick Ehrenberg's "Disc-O-Tech" treatise he mentions adapting the later 2 bolt aluminum MC's to the swap. I have a couple laying around, and will post my findings when I do the conversion.
The swap seems to be a straight forward spindle swap and normal assembly...again, according to Ehrenberg. I am now waiting for mine to be delivered from DVAP...harvested from a 73 Newport.
I realize, and respect that some of you do not like to deviate from "stock/factory" equipment. I am just not of that camp. I intend to drive my car ALOT...and I want the best equipment/system components to support that use.
Using upgraded factory components seems logical to me.
Give the conversion a try yourself...if you can change a ball joint, you can do it.
Also, the Scarebird convertion is WAY cheaper than what you quoted...and NO spindle swap required...
