twostick
Joseph,
You may be experiencing heat-soak; that is when heat saturates the carburetor and the fuel boils in the bowl. This occurs due to the use of gasohol (which boils at a lower temp) and/or due to the engine temperature getting too high. Try lifting the hood when you park your car and see if that helps; if so, it is heat-soak.
My suggestions to actually remedy the problem: use ethanol-free gasoline and get the engine temp down as much as possible. Ethanol-free may be found here: Ethanol-free gas stations in the U.S. and Canada
Engine temp can be lowered by many means, including lower temp thermostat (160 deg.), fan with more blades and a fan clutch, use of a fan shroud, larger radiator, lower heat range spark plugs and backflushing the cooling system.
Best of luck with your problem.
Jeff Dreibus
The Old Carb Doctor
Old Carb Doctor
Ethanol gas... that's the problem. Causes Male pattern baldness too.
CHANGE THE NEEDLE AND SEAT ALREADY!!!
Unless you are running an electric fuel pump with no regulator or a race type mechanical fuel pump with no regulator, it's the only thing it can be if fuel is squirting out the vent tube. If it was boiling fuel which it isn't, it would just bubble over and the floats would have to be too high to get enough fuel in the bowl for it to boil over anyway.
Kevin
