I recently purchased a '57 Desoto Firesweep with power brakes. The brakes were nil when I got the car. I installed new steel brake lines, new rubber hoses to drums, new master cylinder, new wheel cylinders, new shoes, and had the drums turned. The car stops fine, but I have an issue whereby upon pressing the brake pedal the brakes engage but as you start slowing down the car seems to surge like the brakes are disengaging and then engaging.
When I have the car on jack stands and have a friend press gently on the brakes I feel smooth brake pressure through 360 degrees of tire rotation. I checked front and back wheels and they all seem to be acting properly. I was thinking perhaps the vacuum booster might be the cause so I disconnected the vacuum hose and tried a test drive. It took a lot of foot pressure on the brake pedal but the car would slow down. I am not sure if the pulsing was gone or not, but I think it was less. I contacted "Dewey Booster" and he does not think the culprit is the booster.
If anyone has any thoughts on this problem I am having, I sure would appreciated hearing from you.
