Since I own this car (like 20 years), there has been some whining in the rear end. Because I have never driven any other mopar besides my own, I am not sure if this is normal or acceptable. Doesn't seem to get worse over the years as far as I can tell. Next time I take her out cruising, I'll try to make a video.
However, since last year, there's also a clunk in the driveline, manifesting when drving, stepping on the gas pedal after decelerating. That needs some attention, and your help would be highly appreciated, since this is uncharted territory for me...
What I've found out myself:
Dif's oil level's OK
Oil looks clear
It's not a sure grip dif
There's no sideway play in the rear axles (width of driveline)
At least the rear u-joint has some play and needs to be replaced (I will replace the front as well).
I've made two video's and I hope to get some input from you guys as to whether or not there is excessive play in my driveline, and maybe if so, what parts might need to be replaced.
Thanks a lot for your input.
Oil looks clear
