bajajoaquin
Anyone know what the proper ride height is for a '67 Imperial? The FSM says to measure carefully, and make sure the car is within 3/4" side to side, but doesn't say what the proper overall ride height should be.
Are you sure? It should or at least I'm pretty sure I've checked mine against the dimensions in my FSM. I know I checked my Challenger recently from its FSM.
The rear was not adjustable from the factory so that info wouldn't be in the service manual.
Everybody knows the drill now. Rough, rough, crowd.And by the way, are you guys kidding? Do you think I'd put up a question here without checking the FSM? What do you think I am? Stupid? Like ridicule? A slow learner?
:laughing6:
You have to work backwards.Yeah, I get that, but I'm trying to figure out where it should sit. I would have thought there would be a spec somewhere that said, "if your springs are sagging more than this, they need to be re-arched or replaced."
I guess not.
The air shocks would worry me. Springs support weight ..... shocks absorb energy. If the air shocks were kept pumped up they would act like a jack hammer against the upper shock mount. Take a hard look at the mount/crossmember for signs of damage. And disconnect the shocks from the lower mounts before measuring anything.
