All the trick tools are great when you have some experience in handling glass, but for a first timer, I'd really suggest the tried and true method of cutting it out with a wire. Myself, I always just used a piece of music wire and a couple visegips. I've never used the stranded wire they sell... That must have come on the scene when they started gluing them in with urethane.
My method has been to take a long length of wire, usually around .020" (or whatever I could scrounge LOL) and after removing all the trim, I would stick one end through the butyl tape from the outside at the top of the windshield, then get in the car and feed that same end through the butyl at the bottom. Grab the end sticking out with visegrips and the other end of the wire with another pair of visegrips. Use a back and forth sawing motion and cut the butyl all the way around towards one side of the car. Get that all cut and get the wire back through the butyl again and cut the other side. In 5 minutes, the butyl is cut and the windshield is ready to come out.
Tilt the windshield out at the top first and take it out.
If you look in the FSM, there's some illustrations although they use a short piece of wire and a helper.
What hasn't been addressed is you will need new butyl tape for the installation. 3M windo-weld ribbon sealer is what you want. 3/8" diameter. .
Amazon product ASIN B000CQ4AOODon't let someone talk you into using urethane to glue it back in.
If you buy the removal tool at Harbor Fright, get a set of these too... A plastic pry tool can be a real help to get the windshield away for the body as you start to remove it. These things are super handy for other uses and almost disposable.
Nylon Pry Bar Installer Kit, 4 Piece
While not really necessary, I've used a pair of these to handle the windows... 99.99% of the time, I'm working alone, so these have been great for me. Mine aren't HF brand, so I can't say these are good... but probably are about the same.
4-2/3 in., 125 lb. Dual Suction Cup Lifter
