3175375
I believe you are correct. Look at the video posted earlier, to verify.I believe I did drill too far. Lesson learned. I have an NOS a/c heater control and removed a heater control off a parts car I have and bench tested with the actuators on the floor of the car. I checked all the lines with a vacuum pump and all are holding air and moving and holding correctly. with both units the actuators extend on DEF mode and retract on OFF. The shorter shaft actuator retracts on HEAT mode however no, or little air through the floor vents. I rebuilt the air box some time ago and all was cleaned and lubed (if possible, can't remember). The flaps, I am sure could only be installed one way so don't think that's the issue. I only have vacuum lines for two actuators so I think all that is correct. Is there something I am missing or should be trying? The red stripe vacuum lines are on the shaft side from what I read in above post from Detmatt however a different system. Its a non/ac 68' 300.
You would need a tee to operate both the heater/defrost and a/c actuators as there’s a linkage between the two of them.
You should be able to physically see that.
