Cold Case makes excellent radiators. I bought the MOP753A to replace an 18x22 inch High Altitutde auto trans w AC stock Mopar radiator on my 66 Newport, running a 383, 2 barrel. This is the closest thing CC makes to what I had originally. Despite the 2 inch sacrifice in height, their radiator holds about half a gallon more fluid than the old one.
Using a 6 blade 18 inch clutch fan, the shroud for the 18x22 was worthless, as was my 20 inch 7 blade Mopar clutch fan, which forced me to go to the 18" Derale fan from Summit. Rather than construct a custom shroud, though it isn't THAT difficult, just tedious, I opted for a 16" electric pusher fan, which I flick on when I see temperatures over 195 F after the thermostat opens. Mathilda hasn't run with temperatures over 200F last summer or this one consequently. I use a Hayden 2747 clutch.
I LIKE pusher fans as supplemental cooling! Mathilda idles nicely at 500 rpm, which in traffic, alas, doesn't move much air or coolant. This is the situation a pusher fills in very nicely. While a REALLY GOOD shroud will enable a mech engine fan to pull a bit more air past the radiator when in hot stalling traffic, it doesn't add up to 3000 CFM, or even half that, which probably is a more realistic assessment of my cheap sinotrash pusher, especially when my super low idle doesn't engage the alternator. Mind you, as soon as I start moving, the alt kicks up to 14 V @ 60 A, giving the pusher plenty current, but the CRUCIAL state is when idling at stop! Such is the state I note engine temperature staying below 200F, thanks to Cold Case, Derale, and the nameless slaves who make those 16 inch electric pushers in such abundance. WITHOUT the pusher, temperature climbs to 210F in similar conditions.
