you can but it is heavy and awkward. remove the lower column cover, then you need to drop the steering column as far as possible (three 7/16 nuts under the dash and three 1/2 bolts at the firewall). if it is a column shift,don't forget to remove the indicator needle before dropping the column. you'll need to make sure all wiring and the heater control cables are disconnected . speedo cable too.(double and triple check). if you unscrew the a pillar covers and slide them up as far as possible, they should clear when you tip the dash. four screws in the defroster outlets(mine are 3/8 but i'm not sure if they are original). two long 7/16 bolts, one on each bottom lower corner. the dash needs to come straight down off the steering column bolts and then tip it back and it's out.
