MrMoparCHP
if it ain't steamin it ain't overheating.
Alan
Alan
Well... That's not overheating. That's just running a little warm.
Lot's of things could cause it. Air flow for example.... Are all the stock splash shields in place? That old fan clutch is a likely suspect too. Have a fan shroud?
You could change to a 160 degree thermostat. That may or may not make any difference, although it did with my car.
I said to a friend of mine once, and it can be true here: "If you still had nothing but the idiot lights instead of an actual gauge, the temperature wouldn't bother you at all."
After you remove the block drains you may find the holes partially blocked up. Open them up W/ a coat hanger doubled on the end about a 1/4 inch. Reach up in the water jacket as far as you can in all directions w/ the hanger. Next pull the thermostat to confirm its condition, any rubbing or polished marks make it a candidate for replacement. Refill and flush this 2x Times. Warm eng. to oper. temp. Stay close to home and drive it till it is at the 210-215 temp. Return home and monitor eng temp. while spraying the rad. w/ water. Note how fast the temp drops from top to bottom or rad. Slow rate of change = partial plugged rad. Immediate temp change w/ a greater than 30 degree change from top to bottom. Rad. is ok check fan clutch oper. Note: Radiator and fan clutch partial failures are very possible. Please post resultsAfter starting engine and let it warming up at idle it stays at approx 190 F. It goes to 210-215 F when I start driving. Highway or country roads, it doesn't matter. Temp goes up and stays.
While rad was of I inspected and flushed it (again) : no signs of blocked tubes or crud. I do have a fan shroud and checked rad temp with a temp-gun. At top of rad about 215 F to 220 F sometimes, at bottom about 160 F and meassured at different spots on the rad.
I'll try to get those drainplugs out.
I would say that is due to the heat still transferring to the coolant after the engine shuts off, and with no circulation thru the radiator, and no airflow, the water sees about as much heat and expansion as it ever can. The hottest water's heat 'floats' from teh heads, water housing, thru the T-stat and into the radiator, and the heat in the radiator's coolant is floating up as well, making the top tank the hottest part - right where the cap is. Your hi-speed highway run was under high load, but it also had high airflow to compensate. That's just my speculation for explanaation, though.For what's it's worth, my 1968 PK21 with a 440 would puke when shut down after a long hard run. Didn't matter if coolant level was high or low. Now this was back in 1971/on so clogged up cooling system would not apply as the car/engine was less than 4 years old.
about it, after one flat out test run with the speedo pinned for pretty much the whole run round the beltway (100+ miles), dash temp gauge just fine even with the slow drive on secondary roads home, sit in driveway idling for 10 minutes, no temp increase, shut down, PUKE.
Arrrrrgggggggg!
