Landyacht
I have been dealing with what I thought was a detonation issue up until recently when the noise got louder. My motor would seem to make a knocking sound at around 2500 RPM and then go away as engine speed increased or decreased so I didn't suspect it to be a rod knock. I tried playing with timing and did some carb tuning to try to get rid of the problem but was unsuccessful . I eventually switched over to fuel injection which made the car run way better but didn't cure that knock I heard at 2500 RPM. A couple of days ago I noticed the sound getting much worse. It can now be heard at all engine speeds. It started sounding more and more like a rod knock. Today I got the car up on jack stands and dropped the pan to take a look and at first glance everything seemed to look normal. No metal shavings in the oil pan , no discoloration caused by heat on the piston rods. I could still see the hone marks on the cylinder walls. I checked the torque convertor bolts to make sure they were tight. So far I have only opened up one of the piston rods and the bearing looked to be in good shape. the motor has less than ten thousand miles on it and everything still looks clean under there. One thing I did observe is that the motor seemed to shake a lot when I revved it trying to locate the source of the sound. I'm wondering If my problem could be related to weak motor mounts.
