As I’m starting to regain momentum on my neglected 68, I’ve shifted focus to (in my opinion) the most IMPORTANT system of them all - the braking system. I was lucky enough to score a set of 72 disc brakes for my car and they’ve been connected almost 2 years now.
However, now that it’s time to plumb up the brakes - I’m figuring out how to make everything work. Namely, the routing from the MC to the new Metering / Proportioning valve (is there a difference?)
Yes, I know it isn’t a factory style valve but I’d rather spend the money on something new that will work just as great. Mounting it was an issue, as the location for the original Drum / Drum valve didn’t have enough clearance or even the proper mounting hole for the new valve. My friend was nice enough to make me a custom bracket that actually sits up in a good spot on the drivers side frame rail.
There’s a diagram that explains this valve perfectly
Note that there’s is a fitting labeled FRONT MASTER CYLINDER PORT “R”
and another labeled
REAR MASTER CYLINDER PORT “F.”
this is how i interpreted the labels
Am I backwards? Would like to know before I begin to bend any line.
Here’s a pic of the same style valve on another C. Someone sent it to me but I can’t remember who..
and another labeled
