Next thing to do will be to clean the white walls. Any recommendations?
Finally got out to drive some more. It’s been raining non stop here in TN. Next thing to do will be to clean the white walls. Any recommendations?
Howdy.
Big Jim with the Imported to Australia 2 door New Yoker Brougham Coupe
In response to your cleaning question / bestest, easiest thing we use DownUnder is .....
The Steel Wool you buy for Dishes with Soap already impregnated in it !!! Works fantastically aaand CHEAP
Cheers Guys
P.S.
Had to drop a pic in of a REAL MONSTER !!! lol (My Baby)
P.S.S.
Checkout what I'm putting in it next week / Bought at Auction for $2k with $10k's of work !
@PeugFraI did manage to get these with Mymopar.com and Hamtramck-Historical.com:
E85= 440 cid 4 barrel V8 (230hp)
D34= Torque Flight automatic transmission
Y= Imperial
M= medium price class (therefore a LeBaron, though that is obvious post-70)
43= 4-door hardtop
T= see E85
4= 1974
C= Jefferson Avenue, MI, USA
175027: Sequence number
TX9: body color, Formal Black
PLX9= leather seats, black
000= full door panels
227= build date: February 27
Q38541= Order number
V1X= full vinyl top, black
R37= AM/FM Stereo with 8 Track
L35= cornering lamps
M45: fender skirts
N88= auto speed control
V7W= accent stripes, white
N75= Auxiliary transmission fluid cooler
Someone of our Formal gurus could replenish it.
@CollinR
Since your Imp has that special handling tag and the S53 on the fender tag, does it have extra stiff suspension or quicker steering? Codes with an "S" are suspension/steering components.
Something is definitely wrong (sagging pedal sounds like the master is letting go). Formal Imperial brakes are among the best I've experienced. All you need is your big toe on the pedal.Oh you guys are great thank you for all of the information. Yeah I haven’t found J68 anywhere. Definitely would be an interesting code to find. I noticed someone was advertising a 1971 Roadrunner a while back with (J68 PACKAGE) in the title which I found interesting, considering they didn’t explain what the J68 code was.
Sadly all I can compare it to is my pilot and going off of that, the Imp’s steering response is that of an ocean liner, I could play with the steering wheel’s position quite a bit and still keep traveling perfectly straight. The suspension makes the car feel weightless which is especially fun when you go over bumps or slight inclines on the road because the entire car just gradually floats upward which is one of the many cool things I’ve experienced driving it. I surely wouldn’t mind test driving more mid size Imps if they were around >XD. Frankly though I’ve been wanting to test drive a fusie Imp.
The only thing I wish I could change on that car are the Brakes. Despite the MBC rebuild and hose replacements, the brakes take quite a bit of patience and muscle memory to use properly. I don’t know if anyone else here has experienced this but often times I have to press down halfway on the brake pedal pretty quickly for it to grab. Any slower the brake pedal just soggs down to the floor and (sometimes) locks for a few seconds which makes for a terrifying feeling of not being able to properly brake the car, or brake it at all (That happened to me a few months back and I’ve been too nervous to take her out much since) as I said though the brakes work when I hit them halfway with some pressure but if they aren’t pressed a certain way, they almost are non existent. It’s difficult to describe but if the pedal is pressed past that halfway mark it will just limply sink to the floor and there is no grab whatsoever.
The 1977 meaning for J68 is "Dual Battery Charge Unit"
Did somebody call my name? This is quite an honour.
Here the tag codes again, in bold my additions from the Dealership Data Books at the Hamtramck Registry:
Y= Imperial
43= 4-door hardtop
T= see E85
4= 1974
[H53] = Air Conditioner - With Automatic Temperature Control
M45: fender skirts
[P31] = Power Windows
P42 = Security Alarm System
G63 = Mirror, Outside Right, Remote Control
S53 = ???
[G25] = Vent Windows, Manual
J68 = ???
L81 = Fender-Mounted, Turn-Signal Indicators
Two codes remain unresolved and are most unusual for Imperials. On the web one can find "Backlight Louvers" for J68, but there is no confirmation for that on an Imperial. For S53 I ddn't even find anything, something to do with the suspension maybe? Cfr. also N75.
Possibly that's were the special handling tag kicks in. I saw it on another 1974 Imperial, also in connection with Q in the Vehicle Order Number. According to MMC Detroit Q and R were used for "Public Relations" and "Chrysler Lease/Executive".
I did find J68 and S53 on a 1975 Town & Country, however. That one also has the A35 Heavy Trailer-Towing Package. The 1977 meaning for J68 is "Dual Battery Charge Unit" and in 1975 that item was available only as part of the A35 package. So probably both items stem from that package. The package as such could be ordered on 1974 and 1975 Imperials.
I pass and call on @69CoronetRT.
