rags
and posting plenty of pictures, right? get it home yet? failure is not an option.My plan is to get it cleaned up and running best I can without disassembling it
Pretty sure the only option is a custom fabrication, I'm afraid...And a new vinyl top …
Where can I get one ?
1975 Imperial Crown Lebaron Coupe . Been eyeballing this for several years now . 2 owner local car with 71k miles , Economizer , AM/FM/8 Track , Headlight dimmers , Rear Defrost , Leather …. Couldnt get to the underhood but hoping it has 3.23s / tow pkg .
Triple pickle car ! Very excited !
Will need new vinyl top but original paint and sheet metal look amazing other than I 2” faded spot . Interior really nice ! Might need a few seams stitched .
Car drove nice when parked a few decades ago . Turns out the seller and I have many common friends .
I have done a few tops before but never a padded one with a plug . I have a 76 FSM but it is pretty useless for trim items .You should be able to get a new correct vinyl top from SMS, and then have your upholstery guy install it. Make sure your upholstery guy has experience with vinyl tops. Note also that the windshield must be removed in order to install the top. In addition, make sure you have a professional glass guy remove the windshield and re-install it after the new vinyl top is installed. Your upholstery guy may have a relationship with a glass shop / guy who handles the glass for them. The factory FSM for your car probably has chapter and verse instructions for the vinyl top installation process.
And of course somebody had removed the fender tag ! Urghhh…. Why do people do that ?
Making progress ! Had to clear brush for 3 hrs first . A tree had grown against front pass fender and left a palm size wowee. But that should be easy to fix . Body is super straight and I see no signs of rust so far . Underhood was unmolested and still had factory plug wires . Dint get a pic . Will take it home on Monday .
Can you say Thunderbolt and LightfootMaking progress ! Had to clear brush for 3 hrs first . A tree had grown against front pass fender and left a palm size wowee. But that should be easy to fix . Body is super straight and I see no signs of rust so far . Underhood was unmolested and still had factory plug wires . Dint get a pic . Will take it home on Monday .
You still could get lucky with a broadcast sheet tucked away somewhere inside.
Is this what they were driving ? I knew it was a mid 70s C-body but never gave it much more thought. Time to rewatch…Can you say Thunderbolt and Lightfoot
Yeah it should have a few broadcast sheets but it just doesnt make sense to remove the tag on a random driver . This car was traded in by original owners son and was not viewed as a collector piece. So it would have been a service tech or such that removed it . Well thats my presumption….I think PeugFra is right. The interior looks untouched so the broadcast sheet will be most likely still there. Check underneath the front seats. Make sure to remove the seat in order to get the broadcast sheet since its been trapped in the springs for 50 years. Otherwise you´ll tear it apart. If you have it post a picture and we will decipher it. It has all the fendertag codes on it and many more info
what's daddy going to modify in this one? swapping four speeds into formals is legend around here.daddy wanted a RR
