WANTED Screw caps
TerryM
Brisbane, Australia
Can you buy the little trim nut caps anywhere? Not sure the correct name but my 65 fury convertible has them on the bottom trim on the trunk and also on the exposed screws along the top frame. Pics not real flash. Cheers Terry
Not sure if you have a Lowe's down there, but they have drawers full of odd hardware bits.
Certainly the hardware stores and such have lots of nuts and bolts, etc. But if an original look is needed, those stores don't usually have the phosphate or zinc or "whatever"coatings of OEM hardware, nor the captivated washers or a slight flange on that simple acorn nut that Detroit used so long ago.
When I was in the RT tent at Carlisle I was dazzled by all the variations of "plain old common fasteners" that they carry.
