eyemon
Big_John, I found the address after my post sent so will get corrected things going to you Tomorrow
What about manually priming the carb with pulling the air cleaner lid and giving a drink of fuel?
Why do that if there's a better solution? Do you still use a rotary phone?
Even though the electric fuel pump is only used to refill the bowls isn't the pressure from it still to much for a carb application?
No. I know guys that block off the mechanical pump access and run an electric pump full time. This of course requires a regulator as they are running it full time. In the application described in this thread, it should be fine as you are only running it for a couple seconds to fill the bowls.
