The Horvaths
Young man with a cowboy hat
My Uncle has a similar truck. I believe it is a '42.
I want it.....but what the Hell would I do with it
Cummins Diesel, Modern Chassis, Jerr-Dan wrecker flat bed= Great C-Body towing machine.$1500
That's all I would give for a cab and clip to put on a modern diesel chassis.
Yes I would pull apart a single axle straight truck/bobtail, or a school bus. Modern air brakes, normal ten bolt hub piloted wheels and radial rubber.Cummins Diesel, Modern Chassis, Jerr-Dan wrecker flat bed= Great C-Body towing machine.
I'd love to take it out on one of my freeways out here at the probable top speed of 45 mph if lucky.
It has a 2 speed rear in it already.That truck doesn't need to exceed 45 MPH. But if you feel the need, change the rear end ratio.
Yes it should no be going over 45 mph as the brakes are horrible.
Bad brakes on anything are a bad idea no matter how slow you drive, it's the other people that you need panic stop brakes for.
