Something to check when replacing convertible top cylinders
65furyrewind
Chandler, AZ
You can see from the attached photo that the pin which holds the fixed part of the cylinder has come loose from this removable bracket. I noticed it was loose before reinstalling it after a cylinder and hose change. Not sure if it might have worked its way out over time or not. I think it was just a press in fit when the part was manufactured. My solution was to clamp the head down flush with a couple of vice grips and lock it down w three spot welds around the head. Maybe J B Weld would have been good enough.
Also I hooked up the hoses to the two new cylinders and cycled them a couple of times get the air out before installing them in there place. The top hose (top down) cleared easily, but the bottom hose was stubborn. I turned the cylinders upside down so the bottom hoses were now on top and the air cleared in one cycle.
