volksworld
mines been a driver for 20+ years and relatively problem free...but a bad ballast resistor caused a backfire that blew a hole in the muffler...i had bought HP manifolds 20 yrs ago and got a TTI exhaust a while back...and figured i'd swap the manifolds and detail the engine compartment...when i realized i'd have to pull the nose to pull the fender wells to paint the block and to torch the manifold bolts i realized it would be easier to pull the engine...so i gave it a compression test and then leakdown and #5 had 70% leakdown...so full engine rebuild later, pull the dash apart to replace evaporator core (since i wanted to change those 2 little heater hoses inside the box) ,repair rotted dash section and repaint entire dash, pull column to paint ,pull steering box for 2 seals,new fuse box, and just about every thing you can think of in the engine compartment , underdash,front suspension,etc finally get it together and running to take to our mopar show and the functioning-prior-to-the-rebuild gas tank sender dies,the speedo dies, and the left front brake caliper seizes up the night before the show...so that may have been the worlds most expensive ballast resistor
