Speedometer block off plug for an early A727?
Sir Dodge alot
Fairview, TX
Hello and greetings Moparphiles. Need some assistance on this matter.
As the title says, I'm looking for a speedometer block off plug, (speedo gauge is busted)
And since I'm almost done with rebuilding an pushbutton A727, I figured I can get those plugs that fit into the tail case speedo port in the meantime.
The speedo port size in the tailcase measures out to 0.9645 inch.
I'd rather not resort to plugging the port with a core plug with RTV, or slathering RTV on the speedo gear attachment head to seal it up.
(The conventional block off plug will not work, as the newer plugs are for the newer A727 port size of 1.750? Or .8750 sizes)
The obvious choice would be fixing the gauge rather than resorting to this kind of band aid fix, anywho, has anyone on an early pushbutton A727 plugged the speedo port.
If so, how and what did you end up needing to do?
Thank you very much.
