This months Air & Space had a nice article on SR-71 "Rapid Rabbit" (61-7978/2029) which had a crash landing at Kadena in 1972 after flying out of Udorn. Eyewitness account by a aircraft maintenance technician including the procedure for start up in a hanger, taxi surrounded by trucks then to take off and gone in less than 10 seconds. This bird was written off because of the crash.
As it was vectoring in the tower warned the pilot of 35-50 mph gusts 90 degrees across the runway. The tower may have advsed him to find another airport which is impossible if you are flying an SR-71. Low on fuel was one thing and secrecy on landing another. So the pilot came in aligned with the runway's centerline and it looked like a perfect landing. Yet as he deployed his chute a wind gust blew it to port and the nose went to starboard at which point one of the left main landing gear tires blew. Jettisoned the chute, poured on the coals, rotated away from the runway back into the sky to circle around for a second go.
Tech is wondering what the pilot is going to do with no chute, blown tires, and monster crosswinds from a typhoon getting worse. Pilot made second approach, dumped fuel along the entire length of the runway and then circled around for the third approach and landing. As he touched down a fireball engulfed the left main gear. Plane kept rolling, nose up in the air and then the right main tires blew. The Blackbird skidded past him, nose up and tires on fire for 4-5 seconds. When the left main collapsed the wing hit the ground and the left engine exploded. Then the entire airframe began to spin, travelling down the runway at high speed and finally the right main collapsed. The bird kept sliding down the centerline of the runway till it drifted off to the left into grass and came to a stop. Pilot and RIO jump out and run.
Only a recovery crew was allowed near the plane but recovery had to wait as the typhoon was on the base. When it passed, and they brought out a crane to lift the airframe, the crane sunk into the saturated ground. A month later the remains were loaded onto a C-5 headed Stateside. Possibly Beale where they rotated in and out of?
