I know that stanless steel might look nice and shiny and not rust, BUT I suspect such fasteners are harder than normal iron is . . . which is where the problems might arise, to me. All torque specs are formulated to have a certain amount of "stretch" in the bolt/stud to hold against the threads the fastener is screwed into. If the SS fastener is harder, that can chunk all of the factory OEM torque specs out the window into the river, I suspect, as it will stretch less (even the off-shore stuff) than the iron/steel fasteners it was designed for.
Then there might be concerns about heat expansion characteristics between the SS and iron/steel items. Which might make the SS items snap during the hot/cold cycles. Not good.
NOW . . . for some reality issues. The fastener should be softer than the metal it screws into. Not from a "wear" issue, but from the "sacrificial" orientation. Better to drill out a broken soft fastener than to have to re-drill and heli-coil the HOLE itself.
Your judgment call.
