71Polara383
Kid with ballcap
probably waiting on snow to melt a bit.I'm Still waiting on that yard to get time to get me the wiring out of the Monaco you sent me the lead on Wyatt
That looks like such a mess. How long did it take you to swap the harness? If you had to do it again, would you remove the dash?
I figured it could be done leaving the dash in place, but I would think pulling the entire assembly, and accessing all the wiring from the backside would be easier then pulling it apart like this.
This is how I have the Super-lite grounding on my car. Hope it helpsMy Super-lite ground is in an odd space and doesn't look right. Where should it connect on a 69?
Alan
Document this fully please.okay, I got the car out in pittsburgh and I think the next couple weeks I will be working on wiring up the car for the superlite. I know dave just replaced the entire harness, but I dont think it will be that intrusive to just adapt the harness that is already in the car. A lot of stand alone wires have to be created. But I believe only three need to be moved from the bulkhead connector, one removed from the high beam switch and one added onto the headlight connector. I have the terminals for these cars (I believe they are called Packard 56 connectors) and below is what I believe needs to happen:
Remove wire L3-16R from the instrument panel side of spot 27 on the bulkhead connector and move that to the instrument panel superlite switch. (Wire for the high beams)
Remove wire L5-18R from the instrument panel side of spot 27 on the bulkhead connector and move that to the vertical post of the T connector on the super light headlamp relay. (wire for dash high beam indicator)
Add a wire to the bottom of the headlight switch at the same location L2-16LGN connects to. (goes to the superlite headlamp relay)
Remove L4-16V* from the foot dimmer switch and from the instrument panel side of spot 26.
Then all the other wiring connectors in the superlite section of the wiring diagram need to be made.
I do not believe wire M1-18P needs to be moved. I believe that wire can stay where it is and wire L12-16P can be created and piggy backed off of fuse F in the fuse block. Same result should happen, superlite being feed by the dome light circuit (fuse) as the factory intended.
I attached the highlighted wiring diagram for the 70 polara.
this mark up is by using original relays for the superlite. I am not that well versed with relays, but I sure they could be substituted.
I will be documenting the full conversion with the factory stuff I have accumulated when I get around to my 70 wagon.
@rd92west and @300rag -- here is the promised follow-up to the discussion the the three of us started in this other thread.
All the information below is courtesy of Polara Dave (@polara71 who started the present thread). Since he is currently now allowed to post here, but still is the super-helpful guy who helps C-body enthusiasts, he asked that I post here.
"All rear defogger, wagon and convertible cars equipped with the Superlite got the little black 'add on' bezel for the Superlite switch. It wasn't integrated into the panel like the other switches. At that point it was almost like an accessory switch."
So how does one add a superlite switch? Here is Dave's first-hand experience:
"first you have to separate the metal backing plate from the plastic face plate. The bezel in the middle is a non-superlite convertible bezel. The first bezel is the back of the middle bezel. Notice the indent on the left? That is where your superlite switch and light go. YOU have to drill the holes which you can easily screw up ( wrong size, little crooked).
I hope this helps @rd92west."
"The last bezel has the superlite switch mounted, you've seen this one."
My own two cents: it should be clear from the pictures posted above, as well as all the photos posted by @rd92west in the other thread, that the 'tag' describing the button is different for the superlite switch (tag/scrip integrated into the switch) than it is for the other buttons (tag/scrip taped to the wood, under but separate from the switch itself).
A few of us are spending time over at the Drydock.Thanks Dave wherever you are.
