polaraman66
Anybody know where to find the bushings for the sway bar to radius rod bushings and the square bushings that go in the link to the frame for a 66 Polara? Have found all the other bushings, but these.
How different is the MK7064? And regardless which one works or is best, would the solid one be absolutely necessary or would the split ones work?
Thanks for all the help. Wound up ordering a set from RockAuto, Delphi part #TD4554w. the ones i removed where kinda tear drop shaped, not sure if that was original shape, new ones are round with a ridge on the od. I have a corresponding groove in my brackets, so i think they will be ok. the new ones are made of a pretty hard poly. Took a bit of lube and persuasion to get them on the radius rods. Not got it all together yet, so hope they work out.
THOSE are ORIGINALS all right. I had them on Gertrude also. I don't know if Delphi is any better or worse than Mevotech or McQuay-Norris. The former is quite new, but makes good American rubber, the other venerable with some good cause.If your's looked like mine, let me know how your new ones fit. I'm going to be looking for some.
Those bushings do fit properly even tho they do not look anything like the originals. For anybody looking to replace the bushings where the links attach to the stub, i ordered Energy Suspension part no. 9.8177G from O'Rielly Auto parts. They are poly bushings for shocks, but the fit is perfect and are even black, and cost like $16.
I agree. Only place I have used them is on the sway bar, at the frame and the radius rod end. Not found a suitable replacement for the square ones on the links tho. Anybody know where to find them?
Wow! Guess I didnt look everywhere! lol. Thanks Gerald. If it is 2 sets, that would be good, I have several cars!
