68 4spd Fury
Thanks for the replies, I'll replace the sway bar bushings and see what happens.
I agree with this 100%, right down to having the rear bar but not having installed it. In fact, that bar has been on my to-do list so long that when I recently went looking for the shackle-plate mounting brackets, I couldn't find them. After about 10 min of searching I looked under the car for some other reason and realized I had installed the brackets when I swapped to a narrower rearend - back around 2009!I have both the front and rear sway bars from FF. Unfortunately I haven't had time to install the rear one yet, but I will say this. FF may be a bit more expensive, but their customer service is second to none. Their products are also top notch, well engineered and finished; which is rare in the C body world. The front sway bar made a big difference compared to the stock one, and hopefully the rear will add all the more. Save a little more to spring the FF, you won't be disappointed.
I replaced the bushings at the ends and installed the new links from PST, (had to on those, the originals were spot welded and bushings not replaceable). What a difference! Ride improved dramatically.
I replaced my front sway bar bushings about 10 weeks ago and yes, it made a HUGE improvement in handling and driving at interstate speeds. As soon as the weather cool;s down a bit down here, I'm finishing the rest of the front end as the strut rod bushings DO need replacing too. I'm apt to get polyurethane for those and might opt for poly for the sway bar too. Can't overstate how much better Mathilda rides with good rubber in the right places for now though.
I put a set in my 68 (along with a bunch of other stuff) and didn't notice anything overall that was harsh upon hitting bumps (but the car is considerably stiffer overall with FF T-bars and swaybar). I wonder if it is a difference between the Slab's solid-mt subframe vs a Fusey's isolated one? Although I would think the Slab would be harsher with no isolation???You might be fine with poly bushings in most of your suspension pieces, although I personally would not use them for the strut rods. I used the poly bushings in my 1970 Chrysler Newport Custom, and it turned a very smooth, outstanding riding vehicle into a huge nuisance to drive since it crashed and boomed over every little bump - it felt like I could have just put metal there and not used any bushings at all. Although it was a bit of a pain to replace them, I did so the very next day. It was the worst "upgrade" I ever did. What a relief to have normal rubber strut bushings now.
