shaun65Polara
i have discovered all 8 exhaust valve stem seal boots have lifted up from their seats & #5 cyl has a failed piston ring, evidenced by damage to cylinder wall. most of oil loss, however, was coming from passenger bank.
thanks ... the guy i found, he offers service for bronze, at 6-700 bucks compared to knurling, which sure, is short term, but a 59 year old engine which is driven less than a thousand miles/year ... do i really need bronze inserts ?If you look at the knurled surface, when done to spec, it is really quite jagged. The other option is a "bronze heli-coil guide insert". Once the seats are done, then the guide is drilled and grooved for the insert of a bronze heli-coil. The insert is screwed in, then snipped on the ends, and a tool driven into the insert to fully seat and size it. Bronze is supposed to be an excellent wear interface with a chrome valve stem. Not hard to do. Knurling is quite "sub-optimal", although it was "the norm" 60 years ago. Also much less labor that doing "knock-in" guides.
Just some thoughts and observations,
there's a machine shop in Texas that reccommends knurling above guide replacement, if wear tolerances is within .001"Ditto: Bronze Valve Guides!
Knurl is cheap short term inefficient fix,
THAT, i have not yet determinedThat sucks. What was the reason for the stem seal boots to have lifted?
I have never had heads knurled. Our cars don't get driven many miles, so maybe it will work.th
