73Coupe
So anybody know which direction is closed? Mine is rotated all the way clockwise (from the front, or counterweight side). I think gravity pulls it this way if the spring is broken.
It was literally worn over a quarter inch shorter from wear and it was making me think I was having issues from heat. Maybe I was but it was because the pump couldn't refill the bowls sufficiently.Where/how was it worn, and did it lessen the pump action when hot?
Damn, that's a lot! And a good chunk of the pump arm's travel. Are your lifters ok?
Changed the fuel filter last night. Had some rusty gas in there. F. We'll see how she starts after this. Now I gotta probably pull the tank...
I was getting rusty crap in my filter also, so if you pull your tank make sure line under car is clear.
New cam and lifters and I use good oil. I didn't inspect the rod when I did the top end.Damn, that's a lot! And a good chunk of the pump arm's travel. Are your lifters ok?
