SOLD Tested ECU's
halifaxhops
HALIFAX PA
Feedback: 42 / 0 / 0
as marked and the ride in a SFRB All tested on a zetron tester.
The only difference in the circuit / ECM with the dual ballast is that the second ballast resistance feed power into the 5th pin on the ECU. That is no longer used, and unless you find a really old original vehicle or really old NOS, most any new ECU WILL be 4 pin.
You can use a 4 pin box in a 5 pin harness, but not the other way around
