commando1
Close enough for Government work...
How does restricting water flow to the heads get the oil to heat faster? Cos of the warmer temperatures in southern climes I cant see it making much of a difference to the oil's viscosity. It's always been my understanding that winter temperatures and such was what thermostats were designed for?I still believe in getting the oil up to temp that it was engineered to work at.
180? man you gotta get that low-temp wiper switch..165 all day long!
Or union. Oh yea, same thing.Close enough for Government work...
Good Morning, Ross. No Cars n Coffee this morning?Or union. Oh yea, same thing.
I just finished reading thru the whole allpar article...great info!!!:sSig_thanks: Does anyone here run the Evans waterless coolant? Seems like good idea.I always run a thermostat. The reasons below are an excerpt from the Allpar site and most succinctly explain why:
http://www.allpar.com/fix/engines/cooling-system-about.html
The thermostat controls the minimum temperature of the engine. It cannot control the maximumtemperature. The only way the thermostat can cause the engine to run too hot is if it is faulty and doesn’t open completely (or at all).It is commonly, but wrongly, thought that a cooler-running engine is better. It is not! An engine prevented from reaching proper operating temperature because the thermostat is “too cold” (opens at too low a temperature), or missing entirely, wastes fuel, wears faster, and dirties its oil faster. Starting in the late 1960s, higher-temperature thermostats—185°, 190°, 195°, and even 200°—were installed at the factory to help clean up emissions. Hotter coolant means more complete combustion because of less quench-out, so there would be fewer unburned hydrocarbons (HC) and carbon monoxide (CO) in the exhaust.
Generally, and within reason, hotter coolant is better. A hotter engine is more efficient, and there’s less engine wear and longer engine life, because there’s less unburned fuel to wash the oil down off the cylinder walls. The exhaust contains less toxic unburned fuel and carbon monoxide.
