A "seasoned" factory iron block 440 from the '70s that have the thicker webs.
Only go .030 on the over bore and the block itself with carefully chosen components can go 1,000 hp.
WhyTF would anybody want to pay thousands for a crudely hogged out aftermarket block made out of soft material.
People just leave me EFN dumb founded in their supposed logic sometimes.
Why the personal attacks? Because here we go again. The compromises you think are appropriate are smart and well-considered. The compromises other people want to make are idiotic and stupid.
In a street car, why would you build a 1,000 hp combination (you would for sure need headers for that)? If the "capacity" of your block is the standard you want to use, then a KB aluminum block is more than twice as good, since they seem to be good up to about 2,000 hp. (And, by the way, the consensus seems to be that a stock block is good for about 800 hp before the mains start walking.) That sounds to me to be the "EFN dum founded" supposed logic.
Can you explain the soft material part? I don't think that Mercedes aluminum blocks have any problems being too soft, and the late-60s early-70s 4.5 V-8s are pretty awesome engines. And if it really is a problem, you could have just said so, rather than getting so wrapped around the axle.
As for real shortcomings, it seems that the Keith Black blocks have no provision for internal oiling, which would mean external oil lines that generally don't clear stock mounting. Internal oil galleries also require different engine mounts on one side. No provision for a mechanical water pump, either.
World Products claims that their blocks maintain provision for mounting all external factory accessories, but there seems to be some question about quality.
It's also not clear about the durability of the seal of the cast iron liners to the block. There seems to have been some progress in design and assembly, but at least early designs seemed to have something going on there.
I'd be curious to know more information about this (I'm hoping that HeyOldGuy will chime in with some real-life experience).
