live4theking
- Joined
- Nov 24, 2014
- Messages
- 12,730
- Reaction score
- 8,923
Since the duck sat for over 30 years I thought it would be a good idea and since I've got the new radiator there is no reason to pump old fluid into the cooler. I was talking to two the guys I work with that have cars they run a the strip from time to time. One is a Ford guy while the other is a GM guy. They recommended using Type F instead of straight ATF. One of them said it would improve the shifts.
What are your thoughts? Which would you use? I'll probably never run it very hard. The car has either 51k or 151k on it, she was parked around 1980.
Thanks
Thanks
