mr. fix it
Hi there you 727 transmission experts!
have a look at the photo here and give your advice as to where this leak is coming from.
I have learned that a 727 that sits for more than 3 to 5 days can have the convertor drain back into the case then put the trans into an over filled state causing fluid to leak out of the vent at the front of the transmission in the bell housing.
the convertor seal is good as shown to have a dry convertor
At first glance it looks like the pump outer seal is leaking at the bottom but take a good look at the vent on the left.
There is a small drip of fluid which could be the real cause of this apparent leak.
If it is the vent, is there an updated vent I can use to stop this inconvenince other than putting a diaper under the bell housing?
