Transmission problems
The issues with going into "R" from "P" in the morning, first start, are NORMAL for any of those TFs back then. Start them in "N" and there are no problems. Reason is that in "P", there is only lube pressure in the lines, so slower fill of the torque converter after it's drained-back from sitting over night (or longer).
Again, fluid color and condition can "tell the tale" of possible slippage. If it's darker red and smells burnt, that's slippage. With the little mileage on it, since you've had it, hard to perceive the transmission cooked sitting in the garage.
Which gets back to the throttle rod adjustment. This adjustment is mainly about throttle-modulated shift points being where they are or need to be. Kind of like a vac modulator on a GM automatic transmission in that respect. DO make sure the linkage is adjusted per FSM, with the correct amount of preload on the linkage going to the transmission. When that's correct, things can work more like they were designed to work.
Check the ENGINE TUNE, too! Especially related to off-idle throttle response. THAT might really be where the issues are. Is the torque converter stock or has it been "upgraded"? Where is the timing setting at idle? Hot base idle speed? I'm suspecting things are not where they might need to be for best operation, no matter the carb and intake manifold on the engine.
The ONLY reason to replace a transmission is if the case is busted! REBUILD what you have, if needed! Do basic diagnostics BEFORE taking it to a shop. You need to know what they are looking at and why it might look that way. I also noticed a post about this on a C-body Facebook page!
Shop said it had to be pushed back it wouldn’t go into reverse so… yeah
Manual "L/1" and "R" use the same band to work. "Breakaway D" is different. FWIW
Well the verdicts in guys, my Chrysler has a 727 toastflight, so it’s back to the drawing board. Thanks anyways, I was hopeful it would be an easy fix ‍♂️
Is the shop going to rebuild the 727? What experience do you or your friends have with them? Reputation?
I ask these questoins, because a lot of shops have no clue when it comes to older cars.
What is the estimated charge to rebuild?
So I asked the shop I normally take it to (this time took it to my former job as usual shop was too busy) (usual shop will have car again now to work on) and the owner has been working on cars as a mechanic shop since 72’ before that it was a Pontiac dealer. This guy knows his stuff, however, his old tranny tech retired, however he’s been entrusting another shop. I take him at his word, if he trusts it, so do I. He will take mine out and ship it to them.
Sorry to hear ur 60-year-old car needs trans work. I really like the 727s. The one in my New Yorker is still going, even after I worked on it. ;-) Good luck.
