barnfind
Not mine
1987 Plymouth Other | eBay
Only on the surface is this your average Reliant K. For sale is a performant, resto-moded sleeper with classic station wagon aesthetics and utility. Shock your sports car friends with its performance while attracting zero attention on public roads.
The car came with sway bars and polyurethane bushings already installed; combined with a low weight from the factory, the car was satisfying. Despite this, the opportunity to enhance the car's performance in every respect with superior donor components has never been passed up.
Installed:
- low mile turbocharged 1988 LeBaron Intercooled GTS drivetrain (175 hp) <- oem 2.5 (~85 hp)
- adequate fuel pump
- Custom mandrilled exhaust (and then custom-fitted to this car) with cat section
- Shelby Daytona computer <- oem computer
- LeBaron knuckles installed up front <- oem knuckles
- Rear brakes disks <- oem drums
- 11.5" drilled slotted rotors all around
- re-cored copper-frame radiator
- LeBaron sport "wire" wheels
- fresh fuel tank
- Lower control arm polyurethane bushings
- Stiffer front springs
- new Montroe front struts
- rear koni shocks
Included, not installed:
- external oil cooler
- external oil cooler adapter plate
- plumbing
The car WILL PASS smog.
Inquire for additional photos.
Installed:
- fresh fuel tank
- rear koni shocks
- plumbing
